Long time listener, first time caller.
I have two ESP12E modules. One came mounted to a NodeMCU breakout board.
https://drive.google.com/file/d/0BwFbwC ... sp=sharing
The other is a generic board that I have wired myself (see pics for wiring)
I am able to upload sketeches to both of them using the Arduino IDE (version 1.6.8 with version 2.1.0 of Arduino core for ESP8266).
Both boards produce identical output from the CheckFlashConfig sketch. They behave the same until I try to use a sketch that connects to Wifi. Then, the NodeMCU board works but the generic board panics. Sketches that don't connect to Wifi work fine on both. My operating system is Debian (Jessie).
#### Hardware
Hardware: ESP12E
Core Version: 2.1.0 ( I don't know which revision)
### Settings in IDE
Module: Generic ESP8266 Module
Flash Size: 4MB w/ 1MB SPIFFS (tried all 4MB settings)
CPU Frequency: 80Mhz (tried 40Mhz also)
Flash Mode: qio
Flash Frequency: 80Mhz (tried 40Mhz also)
Upload Using: SERIAL
Reset Method: ck
### Sketch
The sketch I'm running is the original CheckFlashConfig script modified to connect to my local wireless network. You can see it at https://gist.github.com/uncletammy/198fec767a8e4803e6af
Here are the debug messages from both boards
##### From NodeMCU board
tail 0
chksum 0x42
csum 0x42
Flash real id: 001640E0
Flash real size: 4194304
Flash ide size: 4194304
Flash ide speed: 40000000
Flash ide mode: DIO
Flash Chip configuration ok.
Joining network
Connected using IP:
10.100.20.136
And MAC address:
5C:CF:7F:0B:70:E0
...still connected!
...still connected!
...still connected!
##### From generic board
Flash ide mode: QIO
Joining network
[WIFI][APlistAdd] add SSID: myNetworkName
[WIFI] delete old wifi config...
there is no poison after the block. Expected poison address: 0x3fff0ff8, actual data: 0x0 0xef 0xef 0xfe
Panic /home/tink/arduino-nightly/hardware/esp8266com/esp8266/cores/esp8266/umm_malloc/umm_malloc.c:851 check_poison_block
ctx: cont
sp: 3fff0090 end: 3fff04d0 offset: 01b0
>>>stack>>>
The decoded stack trace can be seen here: https://cloud.githubusercontent.com/ass ... d33dbe.png
I'm starting to think it's a hardware issue rather than a software issue. Is it possible that as the ESP starts drawing more power (because the network stack is getting started), my circuit is failing to deliver the necessary power to ESP? That's all I can come up with. I appreciate any help or advice. Thanks!
