Thanks in advance for your help!
Best regards
Fernando
Explore... Chat... Share...
There exists internal pull-up resistor in the reset pin, Pin32, which can be left dangled when it is not
used. When the chip is enabled, the reset pin is held low. In order to avoid reset caused by external
interference, the lead is generally required to be short, and no external pull-up resistor is necessary.
The enable pin CH_EN (pin 7) can also serve as a reset pin. If voltage for CH_EN pin is low, the
chipset ESP8266EX will power off. Note that this pin cannot be dangled.
