the sensors are simlpy labeled as DS18B20. I'm using them in powered mode.
Explore... Chat... Share...
martinayotte wrote:You're lucky and probably don't have lot of ESR intereferences around.
The Dallas specs are really mentioning 4K7 as the standard way to pull it up.
