By krzychb
#43001 Hi xtal,
To detect what Arduino version the sketch was compiled with you can check ARDUINO constant.
Sample sketch:
Code: Select allvoid setup()
  Serial.print("The 'ARDUINO' constant contains: ");
  Serial.println(ARDUINO);
  if(ARDUINO == 10608)
    Serial.println("You are running Arduino IDE 1.6.8");
void loop() {}
Output on serial monitor:
Code: Select allThe 'ARDUINO' constant contains: 10608
Krzysztof
