Updated schematic below - taking into account your feedback.
Can someone perhaps suggest which N-Chan mosfet and diode would fit in this schematic - I believe the door strike solenoid doesn't draw more than 400mA @ 12vDC.
Many thanks!
Explore... Chat... Share...
markusonfire wrote:I've found the FQP30N06L/RFP30N06LE http://littlebirdelectronics.com.au/products/n-channel-mosfet-60v-30a N-Channel Mosfet which should do the job with the above schematic. also I've picked up some 1A 12v diodes for the flyback.
