Report Bugs Here
Moderator: Mmiscool
By kingedem
#43609 Hi Micheal,
I found following 2 issues with new version ESP Basic 1.89.
1. "wget" function not fetching html string from URL ("example.com").
2. "load" function not working.
Thanks.
By Mmiscool
#43632 Just uploaded a new build fixing the problems you identified.
After some testing also noticed the following.
Also I noticed that you must add a slash at the end of the url it it is just a naked domain name. IE
print wget("example.com/") not wget("example.com")
With out the slash at the end there or a proper page name it responded with a "400 Bad request". Adding the slash returned a proper page.
Load now needs the full path to the script you wish to run.
ie. LOAD "\myscript.bas"or LOAD "\uploads\myscript.bas"
By kingedem
#43637 Micheal,
Version 1.90
load function working as per your below detail mentioned : load "/file.bas"
but, wget still not working ... it returning "</html>" ...
i am using following code:
[sub1]
var1 = wget("myurl.com/")
wprint var1
wait
Mmiscool wrote:Just uploaded a new build fixing the problems you identified.
By Mmiscool
#43639 It will return the html of a web page if that page consists of html.
Can you give me a good exmple of a url you are trying to fetch and the expected result you are looking for?
