By alonewolfx2
#4365
haroldjclements wrote:Thank you for your reply jankop. What value resistor do you suggest?
Thanks again,
Harold Clements
i am using 2.2k but probaply more than 1k works
By haroldjclements
#4372 Unfortunately, still not communicating. I put a 2K resistor between RST and GPIO0 (I take it that is all that is required?). I found that the WiFi transmitting stops. Again tried the terminal emulator at 115200, 57600 and 9600 baud rate. :cry:
The only thing I can think of is that the device is faulty in some way..
Thanks again, I do really appreciate all the help that you guy have provided...
PS. Will try a resistor in the 4K7 - 10K range...
