Have now replaced the wire with a 470R resistor to see if it helps. Will try a bit lower if necessary but so far so good!
Explore... Chat... Share...
martinayotte wrote:@AdrianM, For the CH_PD, I would never rely on weak internal PullUps, especially that Espressif is saying the following since the beginning in the HardwareUserGuide :The enable pin CH_EN (pin 7) can also serve as a reset pin. If voltage for CH_EN pin is low, the
chipset ESP8266EX will power off. Note that this pin cannot be dangled.
3.1.1. General Purpose Input/Output Interface (GPIO) There are up to 17 GPIO pins. They can be assigned to various functions by the firmware. Each GPIO can be configured with internal pull-up (except XPD_DCDC, which is configured with internal pulldown)
lethe wrote:CH_PD & GPIO16 are not the same pin.
CH_PD is a dedicated enable pin and cannot be configured as I/O (in newer datasheets it's called CHIP_EN/CHIP_PU).
