Looking at getting my self a "uCurrent Gold", but those are out of stock at the moment.
Explore... Chat... Share...
gurucafe wrote:fasmide wrote:I have an old fluke and a cheap uni-t and none of them are able to measure the current usage in sleep mode - i did remove the red LED to minimize the sleep current..
Im running mine from a Pololu U1V11A stepup with two AA batteries. Wakes up every 5 minuttes, takes a reading from a dht22 sensor and posts results to a webservice. Until i find something that can measure it - time will have to tell how long it runs on these two batteries.
EDIT: code at https://github.com/fasmide/esp_dht22
Anyways, looking at https://github.com/esp8266/esp8266-wiki ... e_versions - it seems there is no versions with both the rst and GPIO16 breaked out?
Hi,
Could you please let me know, how long it runs with 2 AA batteries in your case?
BTW, could you please also push latest code (if any) to Github? Thank you.
Have a nice weekend!
gurucafe
