- Wed Dec 10, 2014 3:17 am
#4462
I compiled the cross tool-NG on MAC OS X and I am using it. It seems to be ok. I have compressed the cross tool-NG and the size is about 30MB. If you need, please provide me a place to upload it, You also need to build esptool for OS X. Other tools are Python so it can easily work on MAC.
I follow the steps in
viewtopic.php?f=9&t=224&start=30"
Next, some notes for those on a Mac.
Create a case-sensitive filesystem image and mount it somewhere before cloning crosstool-NG:
1 hdiutil create -size 10g -fs "Case-sensitive HFS+" -volname ESPTools ESPTools.sparsebundle
2 hdiutil attach ESPTools.sparsebundle
3 ln -s /Volumes/ESPTools/ esptools
4 Install gcc 4.9. I use macports, homebrew should also work. Note that you may also need to install other packages, I might have had them installed already. If you use macports, don't forget to set the default gcc:
5 sudo port select gcc mp-gcc49
6 When running configure, encourage it to pick the GNU version of grep (which also has to be installed via macports/homebrew):
grep=/opt/local/bin/grep ./configure --prefix=`pwd`
Before doing ct-ng build, run menuconfig ($ ./ct-ng menuconfig), go into "C compiler" and disable "Link libstdc++ statically into the gcc binary". Otherwise crosstool-NG will feed '-static' option to gcc, but on OS X gcc doesn't have it.
I am using an external drive formatted as cast-sensitive file system and I built the whole thing in there. You also need to install MacPorts so that you can install gcc 4.9 and other needed tools. Now, I am happy that everything are working on my MAC.
