Google says: (-1000) modulo 10 000 = 9000
Wolfram Alpha says: (-1000) mod 10000 = 9000
So 2 out of three cats...
Explore... Chat... Share...
picstart1 wrote:The correct answer is always 9000. Modulo has a strict mathematical definition.
To move to -1000 from an arbitrary modulo zero position (say 10000) involves two retrograde steps of 10,000 and the last step has a remainder of 9000. The result of a Modulo operation is the remainder.
-(1000 mod 10000)is different in that the bracket causes the mod to operate on 1000 prior to infix setting the sign.
