Report Bugs Here
Moderator: Mmiscool
By Guy Fortabat
#45325 Hi,
I did some more testing. Got also to my friend's rocket PC and it is still the same.
I am connected through the Wifi to the Wemos name "ESP".
I'll be happy to connect in STA mode. Can you give me the tip for that ?
For sure all this is new for me !
Thanks for helping.
Guy
Here is a log of what's happening:
Connection to Wifi ESP quite long 20 sec.
[FILE-MANAGER] times-out. «Retry» button used.
Login box ok but ends in [SETTINGS] instead of File-manager.
Ends-up correctly in the file-manager.
File - Rename takes 15 secs to show the renaming screen.
After renaming another 15 secs to show the file-manager screen.
[VARS] takes 3 secs.
[FILE-MANAGER] another 10 secs.
Time_out message = ERR_EMPTY_RESPONSE
By cicciocb
#45328 Hi Guy,
to connect in STA mode you need to fill the parameter page.
The instructions are provided here :
http://www.esp8266basic.com/editor-interface.html
Setting page, enter the name of your WIFI connection (NEUF_xxxx, ....) and the wifi password then click on save.
Resetting the ESP, it should connect on your local router; the assigned IP will be shown on the serial port.
By Guy Fortabat
#45343 Yes, STA mode runs nice !
No timemout messages or boxes.
Menu items works fine also.
Your helping is very productive on my side.
Just for my understanding:
How or why are 2 IP adresses shown ?
192.168.4.1 natively and 192.168.43.133 in the terminal ?
Thanks a lot !
Guy
By cicciocb
#45370 Hi,
the IP 192.168.4.1 is fixed as soon as the ESP is in AP mode, whenever the other address is given by the DHCP server of your router; in your case the local IP of your router should be 192.168.43.1.
