In one of your earlier schematic, the C2 was 100uF, and on latest it is now 10uF.
You should keep the value at 100uF or even more if you can.
This is the "power reserve" which will prevent spikes.
Oh ! I see :
Okay, i will do that. I just changed the value to the value which was used in the datasheet for the voltage regulator HT7333.
Edit: I changed my schematic again: https://www.docdroid.net/bn6yQzS/schema ... 6.pdf.html
So final thoughts, is this going to work?
