I have a very simple sketch which uploads successfully to the ESP-01:
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
Serial.println("LED On!");
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
Serial.println("LED Off!");
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
It uploads successfully as the Arduino IDE says, "Done uploading" and the output below shows:
Uploading 235344 bytes from to flash at 0x00000000
Upon reboot the LED flashes as I expect, but I get no output via my terminal emulator (puTTY, Arduino Serial Monitor, etc.)
I've verified the speed I choose in the terminal emulator is 115200 but nothing..
Any ideas?
