Moderator: Mmiscool
By kbaykar
#46981 Also, I did some "AJAX" based programming on the same matter. I think this is the best, profound solution on this matter. Code as follows:
Code: Select all'///////////////////////////////////////////////////////
' Mainstream program code.
memclear
let myRetMsg = ""   'initialize, holds returned message!
let retSerDat$ = "" 'initialize, holds returned serial data!
let sdc = 0         'initialize, controls arrival of serial data!
cls
wprint "<!DOCTYPE html>"
wprint "<html><head><meta charset='UTF-8'>"
wprint "<body>"
wprint "<h2>AJAX Demo with ESP Basic</h2>"
wprint "<button type='button' onclick='runAjax()'>Request Data</button>"
wprint "<p id='demo'>Data = B l a n k</p>"
wprint "<script>"
wprint "function runAjax() {"
wprint "  var xhttp = new XMLHttpRequest();"
wprint "  xhttp.onreadystatechange = function() {"
wprint "    if (xhttp.readyState == 4 && xhttp.status == 200) {"
wprint "      document.getElementById('demo').innerHTML = xhttp.responseText;"
wprint "    }"
wprint "  };"
wprint "  xhttp.open('GET', 'msg?Param=Request', true);"
wprint "  xhttp.send();"
wprint "}"
wprint "</script>"
wprint "</body>"
wprint "</html>"
print
msgbranch [espMsgResponse] 'define handler for MSG URL feature!
serial2begin 19200,14,12   'setup soft implemented Serial2 port!
serial2branch [serial2in]  'define handler for receiving Serial2 port data!
wait
' MSG URL Handler code.
[espMsgResponse]
msgget "Param" sendSerDat
serial2println sendSerDat 'send the request to Serial2 port!
do                        'although we run an endless loop here, one can simply implement a timeout mechanism!
loop until sdc > 0        'waiting for the arrival of serial data!
let sdc = 0
let myRetMsg = "Data to/from Serial2 Port= " & sendSerDat & " / " & retSerDat$
msgreturn myRetMsg
wait
' Serial2 Port Handler code for data receival.
[serial2in]
serial2input retSerDat$   'receive serial data!
let sdc = 1               'signal that serial data received!
return
Pressing "Request Data" button starts a XMLHttpRequest, which ends up in MSG URL Handler code. Inside it, we send a "Request" text out from Serial2 port.
Using a terminal program (like RealTerm), I receive the request and by pressing a button send "Reply" text to Serial2 port. Serial2 Port Handler code receives the reply text, then sets a flag (sdc) to allow program to continue down inside the MSG URL Handler code. Which in turn runs "msgreturn" instruction.
Return from MSG URL Handler triggers "document.getElementById('demo').innerHTML = xhttp.responseText;" statement to run. This updates data on the screen. This is the way of how "Ajax" works.
Inside the MSG URL Handler code, "do loop" runs endless. This is because, I reply the request to Serial2 port manually. Normally a program will receive the request and reply it very shortly. So it is obvious that a timeout must be implemented, and when it occurs an appropriate warning or error reply should be returned. One can simply implement this timeout code to his/her own needs and taste.
I prepared some small screenshots to betterly describe the matter. However somehow could not paste them here. If you like, I can prepare a sort of article, featuring screenhoots, I can email it to you. So, you can include it in examples on ESP Basic web site. I think it is worth to be included there.
By Electroguard
#46991 It seems that pics cannot be uploaded to the ESP8266 forum (not just ESP_Basic forum) from your local machine (not from mine anyway). I assume it's to prevent bulky pictures being hosted on the forums server(s), but that's just a guess.
So you need to have pics published online somewhere and use their online url to link to the pic from the post. Well that's my understanding of the situation anyway, but it's not something anyone has ever explained to me.
