By Salil dhawan
#47857 Hi guys,
I was trying to play around the SSDP example, but it was not working for me. The only change which I made to the file is to change the wifi Login and password. The code is attached below. Is there anything else I need to change ?
I am using Wemos D1 mini.
I have attached the description.xml results.
My PC does have the SSDP services enabled. I am able to see other devices on network. Please help.
#include <ESP8266WebServer.h>
#include <ESP8266SSDP.h>
const char* ssid = "************";
const char* password = "***********";
ESP8266WebServer HTTP(80);
  Serial.println("Starting WiFi...");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if(WiFi.waitForConnectResult() == WL_CONNECTED){
    Serial.printf("Starting HTTP...\n");
    HTTP.on("/index.html", HTTP_GET, [](){
      HTTP.send(200, "text/plain", "Hello World!");
    HTTP.on("/description.xml", HTTP_GET, [](){
      SSDP.schema(HTTP.client());
    HTTP.begin();
    Serial.printf("Starting SSDP...\n");
    SSDP.setSchemaURL("description.xml");
    SSDP.setHTTPPort(80);
    SSDP.setName("Philips hue clone");
    SSDP.setSerialNumber("001788102201");
    SSDP.setURL("index.html");
    SSDP.setModelName("Philips hue bridge 2012");
    SSDP.setModelNumber("929000226503");
    SSDP.setModelURL("http://www.meethue.com");
    SSDP.setManufacturer("Royal Philips Electronics");
    SSDP.setManufacturerURL("http://www.philips.com");
    SSDP.begin();
    Serial.printf("Ready!\n");
  } else {
    Serial.printf("WiFi Failed\n");
    while(1) delay(100);
  HTTP.handleClient();
  delay(1);
