martinayotte wrote:Glad to hear that you figured out that some of the problem was power supply related ...
For the PHP script, what kind of server are you using ?
Because if it is only accepting HTTP/1.1 request and refuse to respond to HTTP/1.0, then your request will require the addition of "Host: <webserverIP>" before the "\r\n\r\n".
(you can verify if this is the issue by trying the current request in a telnet)
I'm pretty sure the problem isn't in the code down there, and that the problem is with the Arduino sending the AT commands to the board. When I connected to it with Putty, I sent it all the commands to connect to my network and assigned it a static IP. After that I could ping the device, and if I typed in the GET in the sketch it would do what it was supposed to do.
When I unplugged it from the FTDI board and reconnected it to the Arduino, I can ping it's IP, but if I try to change the static IP via the sketch, it doesn't change, it would appear what I wrote in there via Putty is still there, and the sketch isn't changing it.
That's where I'm stuck right now.
