I've managed to get it working, but after I've disabled the DHCP server on the configuration page and entered the SSID of my network which has a DHCP server, somehow the ESP boots up with IP-address 0.0.0.0
Is there any way to reset it back to the default 'myWebServer' so I can try to re-configure it?
I've tried to upload the code again, but that didn't help. Also a reset didn't do the trick.
so currently it is connecting to your SSID/router but assigning itself 0.0.0.0 from the config form....thats why it can't be accessed....
hmmm...you may have to reflash it with a stock nodemcu image first (erase the flash contents).. Or if you shut off your router for a minute and startup the esp, if the esp can't connect to the SSID it will start its local softAP....then you connect to the SoftAP with phone/notebook and reconfigure....
let me know
I believe I need to do this:
The esp device requires it to be a nodemcu type - erased? or will the arduino flash take care of it.
I run Aduino IDE 168 with proper libraries.
I flash -- myWebServerSample.ino to the esp.
Once its flashed and i reboot , connect to local lan and a webserver will appear, with the option to upload other html files via ota.
Should i then load all the html examples displayed in github html dir ?
Thanks for the project and clarification.....
Joe
