Warthog wrote:> Also never ever supply 3.3V to GPIO2. I burnt two of them by doing so.
Why that? I thought GPIO ports are 3V3 save.
During startup GPIO2 is used as output UART Tx1 . 3v3 will damage the pin when it outputs low.
Explore... Chat... Share...
picstart1 wrote:...
An esp-03 device will program with the same connections see below.
Solved issue was gpio-15 needs to be pulled down
