By timathis
#49392 Hot is not good!!
What kind of multimeter? The 450E could possibly on some meters mean error or greater than highest reading of meter.
Usually you would get flashing display with the E however indicating a very high input impedance.
I assume you measured it with no power applied.
Use the diode test range it your meter has one.
If you get close to the same reading with a known good one consider it bad.
