- Thu Jun 16, 2016 6:31 pm
#49297
I have adapted my code so that you can set the number of sliders by changing the variable 'sliderMAX' in line 10. Change this value to experiment with the number of sliders. You don't have to copy chunks of code over and over, you can use for-loops and passing variables in functions to do the job for you. I keep track of all the slidervalues and the ESP-variables in arrays (check line 11).
This works fine on my computer. I have tried it with 50 sliders and it still renders the website just fine. But remember that in Ajax, the variables are written to or retrieved from the XML-file and that takes time. If the number of sliders is big, the blinking of the led gets irregular (remember that my led is on pin 16, yours may be on another pin. Check line 9). I think the speed of your computer limits the number of variables (sliders) it can handle.
Enjoy, Peter.
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
const char* ssid="yourSSID";
const char* password="yourPASSWORD";
String webSite,javaScript,XML;
unsigned long wait000=0UL,wait001=1000UL;
int LED=16;
const int sliderMAX=10; // This sets the number of sliders you want
int sliderVal[sliderMAX]={60},ESPval[sliderMAX];
void buildWebsite(){
buildJavascript();
webSite="<!DOCTYPE HTML>\n";
webSite+="<META name='viewport' content='width=device-width, initial-scale=1'>\n";
webSite+=javaScript;
webSite+="<BODY onload='process()'>\n";
webSite+="<BR>This is the ESP website ...<BR>\n";
webSite+="Runtime = <A ID='runtime'></A><BR><BR>\n";
webSite+="<TABLE BORDER=1 style='text-align:center;border-collapse:collapse'>\n";
for(int i=0;i<sliderMAX;i++){
webSite+="<TR>\n";
webSite+="<TD><BR><INPUT ID='slider"+(String)i+"' TYPE='range' ONCHANGE='Slider("+(String)i+")'></TD>\n"; //in Firefox, Chrome and Edge use ONINPUT
webSite+="<TD>Slidervalue"+(String)i+" = <A ID='Sliderval"+(String)i+"'></A><BR>\n";
webSite+="ESPval"+(String)i+" = <A ID='ESPval"+(String)i+"'></A> milliseconds</TD>\n";
webSite+="</TR>\n";
webSite+="</TABLE>\n";
webSite+="</BODY>\n";
webSite+="</HTML>\n";
void buildJavascript(){
javaScript="<SCRIPT>\n";
javaScript+="xmlHttp=createXmlHttpObject();\n";
javaScript+="function createXmlHttpObject(){\n";
javaScript+=" if(window.XMLHttpRequest){\n";
javaScript+=" xmlHttp=new XMLHttpRequest();\n";
javaScript+=" }else{\n";
javaScript+=" xmlHttp=new ActiveXObject('Microsoft.XMLHTTP');\n";
javaScript+=" }\n";
javaScript+=" return xmlHttp;\n";
javaScript+="}\n";
javaScript+="function process(){\n";
javaScript+=" if(xmlHttp.readyState==0||xmlHttp.readyState==4){\n";
javaScript+=" xmlHttp.onreadystatechange=function(){\n";
javaScript+=" if(xmlHttp.readyState==4&&xmlHttp.status==200){\n";
javaScript+=" xmlDoc=xmlHttp.responseXML;\n";
javaScript+=" xmlmsg=xmlDoc.getElementsByTagName('millistime')[0].firstChild.nodeValue;\n";
javaScript+=" document.getElementById('runtime').innerHTML=xmlmsg;\n";
javaScript+=" for(i=0;i<"+(String)sliderMAX+";i++){\n";
javaScript+=" xmlmsg=xmlDoc.getElementsByTagName('sliderval'+i)[0].firstChild.nodeValue;\n";
javaScript+=" document.getElementById('slider'+i).value=xmlmsg;\n";
javaScript+=" document.getElementById('Sliderval'+i).innerHTML=xmlmsg;\n";
javaScript+=" xmlmsg=xmlDoc.getElementsByTagName('ESPval'+i)[0].firstChild.nodeValue;\n";
javaScript+=" document.getElementById('ESPval'+i).innerHTML=xmlmsg;\n";
javaScript+=" }\n";
javaScript+=" }\n";
javaScript+=" }\n";
javaScript+=" xmlHttp.open('PUT','xml',true);\n";
javaScript+=" xmlHttp.send(null);\n";
javaScript+=" }\n";
javaScript+=" setTimeout('process()',1000);\n";
javaScript+="}\n";
javaScript+="function Slider(cnt){\n";
javaScript+=" sliderVal=document.getElementById('slider'+cnt).value;\n";
javaScript+=" document.getElementById('Sliderval'+cnt).innerHTML=sliderVal;\n";
javaScript+=" document.getElementById('ESPval'+cnt).innerHTML=9*(100-sliderVal)+100;\n";
javaScript+=" xmlHttp.open('PUT','setESPval?cnt='+cnt+'&val='+sliderVal,true);\n";
javaScript+=" }\n";
javaScript+="}\n";
javaScript+="</SCRIPT>\n";
void buildXML(){
XML="<?xml version='1.0'?>";
XML+="<xml>";
XML+="<millistime>";
XML+=millis2time();
XML+="</millistime>";
XML+="<sliderval"+(String)i+">";
XML+=String(sliderVal[i]);
XML+="</sliderval"+(String)i+">";
XML+="<ESPval"+(String)i+">";
ESPval[i]=9*(100-sliderVal[i])+100;
XML+=String(ESPval[i]);
XML+="</ESPval"+(String)i+">";
XML+="</xml>";
String millis2time(){
String Time="";
unsigned long ss;
byte mm,hh;
ss=millis()/1000;
hh=ss/3600;
mm=(ss-hh*3600)/60;
ss=(ss-hh*3600)-mm*60;
if(hh<10)Time+="0";
Time+=(String)hh+":";
if(mm<10)Time+="0";
Time+=(String)mm+":";
if(ss<10)Time+="0";
Time+=(String)ss;
return Time;
void handleWebsite(){
buildWebsite();
server.send(200,"text/html",webSite);
void handleXML(){
buildXML();
server.send(200,"text/xml",XML);
void handleESPval(){
int sliderCNT=server.arg("cnt").toInt();
sliderVal[sliderCNT]=server.arg("val").toInt();
buildXML();
pinMode(LED,OUTPUT);
WiFi.begin(ssid,password);
while(WiFi.status()!=WL_CONNECTED)delay(500);
WiFi.mode(WIFI_STA);
Serial.println("\n\nBOOTING ESP8266 ...");
Serial.println(ssid);
Serial.print("Station IP address: ");
server.on("/",handleWebsite);
server.on("/xml",handleXML);
server.on("/setESPval",handleESPval);
server.begin();
server.handleClient();
if(millis()>wait000){
buildXML();
wait000=millis()+1000UL;
if(millis()>wait001){
digitalWrite(LED,!digitalRead(LED));
wait001=millis()+ESPval[0];
