By Joe Job
#52344
Code: Select allSystem Initiating...
Mounted file system!
Exception (3):
epc1=0x401003e9 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40015499 depc=0x00000000
ctx: cont
sp: 3fff1fd0 end: 3fff2380 offset: 01a0
>>>stack>>>
3fff2170:  00000000 ffffffff 40203490 3fff3528
3fff2180:  3fff3220 000f8000 0000007c 3fff2280
3fff2190:  00000484 00000484 000003fd 401004f4
3fff21a0:  00000000 00001000 000003fd 40107348
3fff21b0:  40004b31 3fff21e0 0000001c 40229c09
3fff21c0:  40105dbe 40229cf1 3fff4584 000003ff
3fff21d0:  000003fd 3fff2280 3fff4584 000003fd
3fff21e0:  ffffff00 55aa55aa 0000001a 0000001c
3fff21f0:  0000001c 0000008b 00000089 000003ff
3fff2200:  4022a0e0 3fff4584 3fff4584 000000ff
3fff2210:  00000001 3fff22a0 4022a267 00000008
3fff2220:  3fff4584 000000ff 3fff2280 00000000
3fff2230:  3fff4644 3fff22e1 00000001 4022a2f4
3fff2240:  3fff2280 3fff4584 3fff0f64 3fff0f58
3fff2250:  3fff22a0 3fffa8bc 3fff4584 3fff0f64
3fff2260:  4022a330 3fff1104 00000000 3fff126c
3fff2270:  402085fc 3fff44fc 00000000 4010053d
3fff2280:  3ffe8f00 feefeffe feefeffe 3fff0f58
3fff2290:  00000010 3fff3cd0 3fff3cd0 3fff0f58
3fff22a0:  00000000 3fff44fc 3fff44fc 4020f844
3fff22b0:  3ffeac8c 00000000 3fff44fc 4020f893
3fff22c0:  3ffeac8c 3fff3cb4 3fff44fc 4020f8c5
3fff22d0:  4022995e 00000001 3ffeac8c 3fff0f64
3fff22e0:  4020839f 3ffeac8c 3ffeac8c 40209e00
3fff22f0:  3ffe9508 3ffeac8c 3fff1104 40207441
3fff2300:  3fff0f64 3ffeac8c 3fff3c2c 40207b04
3fff2310:  feefeffe feefeffe feefeffe feefeffe
3fff2320:  feefeffe feefeffe feefeffe feefeffe
3fff2330:  feefeffe feefeffe feefeffe feefeffe
3fff2340:  feefeffe feefeffe feefeffe feefeffe
3fff2350:  feefeffe feefeffe feefeffe 3fff1350
3fff2360:  3fffdad0 00000000 3fff1348 40210470
3fff2370:  feefeffe feefeffe 3fff1360 40100718
<<<stack<<<
c_ÇrSöfjüSystem Initiating...
Exception (3):
DECODE:
Code: Select allDecoding 23 results
0x40203490: spiffs_obj_lu_scan_v at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_nucleus.c line 941
0x401004f4: calloc at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1684
0x40107348: pvPortZalloc at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/heap.c line 33
0x40229c09: wifi_param_save_protect_with_check at ?? line ?
0x40105dbe: spi_flash_read at ?? line ?
0x40229cf1: system_param_save_with_protect at ?? line ?
0x4022a0e0: wifi_station_ap_number_set at ?? line ?
0x4022a267: wifi_station_ap_number_set at ?? line ?
0x4022a2f4: wifi_station_ap_number_set at ?? line ?
0x4022a330: wifi_station_set_config at ?? line ?
0x402085fc: ESP8266WiFiSTAClass::disconnect(bool) at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFiSTA.cpp line 510
0x4010053d: _umm_realloc at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1491
:  (inlined by) realloc at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1709
0x4020f844: String::changeBuffer(unsigned int) at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x4020f893: String::reserve(unsigned int) at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x4020f8c5: String::copy(char const*, unsigned int) at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x4022995e: wifi_get_opmode at ?? line ?
0x4020839f: ESP8266WiFiGenericClass::mode(WiFiMode) at c:\users\usuario\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2/functional line 1954
0x40209e00: HTTPUpload::HTTPUpload() at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src\detail/RequestHandlersImpl.h line 53
0x40207441: initiateAccessPoint() at C:\Users\Usuario\Transporter\TECHNOLOGIES-IoT\_TechBubbleProductMasters\Devices\ThermaSenseDS\ThermaSenseDS/ThermaSenseDS.ino line 319
0x40207b04: setup at C:\Users\Usuario\Transporter\TECHNOLOGIES-IoT\_TechBubbleProductMasters\Devices\ThermaSenseDS\ThermaSenseDS/ThermaSenseDS.ino line 392
0x40210470: loop_wrapper at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_main.cpp line 56
0x40100718: cont_norm at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/cont.S line 109
By Joe Job
#52354 After changing the settings back to 512k and 128 k spiffs the above no longer happens but the flash check script tells me these are incorrect settings for my 12f. I suggested the issue was related to this a while ago, what could be causing this to happen?
By Joe Job
#52357 Well I tried working this out but now even more issues, previously I have been able to power all of my ESP01 projects with either a 5v adapter through a 3.3 AMS1117 or a 12v adapter through an AMS1117. With the 12f this is not the case, neither 12v through the AMS1117 or 5v through the AMS1117 works, the blue light turns on when powered up but nothing else happens, no data sent to the broker, no will message that the device is on, serial does not work (although 12v did today with serial). On both the 12v and the 5v the voltage coming out of the regulator is 3.23. Connecting both of these adapters up to previous devices ( 1 with only an ESP 01 and magnetic reed switch and one with an ESP 01, Atmeg328P-pu and PIR sensor) it all works as expected. The only way this now works is a 3,3v Foca v2 programmer that is giving out on average 2.88 - 2.90 v. Batteries suddenly stopped working after 7 hours of functioning on about 2.75v and after that no new batteries would power it despite them giving out the same voltage as the Foca near enough.
Added to the issues of the PIR sensor with the ESP-01 alone, the issues with ESP-01 alone with a relay, the ESP-01 alone with the NFC scanner, the issue with HTTP update, the issue with the flash size script telling me that I need to change to 4m in the IDE settings yet when doing this it crashes every single time and all the others I think it is safe to say my days with ESP are almost at an end. I am going to try with the ATTiny method and ESP-01 and also the SSR relay and if still issues I am left with no choice but to find something else which at this stage in the development is an absolute killer.
Oh have it running with the Foca and now it is starting to crash with that,
I am going back to easy stuff like machine learning and building artificial staff members :D Sorry for the rant but I am fuming how much time has been wasted this weekend, but thanks to those that tried to help.
