ESP07 programs OK as 1M module.
will take the can off one of them to physically check the flash memory.
Explore... Chat... Share...
Moderator: Mmiscool
Hello, you must use 1M to flash the esp-07 from Ai-Thinker it has 1024kbit for Data, the Chip is a "25q80assig" from BergMicro. - See more at: viewtopic.php?p=35271#sthash.DBP2kUFB.dpuf
