i have been trying to make this
http://www.instructables.com/id/ESP8266-5-internet-controlled-switch/step4/Hardware/
and i have succeeded with esp8266-01
now i try to make the same with esp8266-12 all other material the same.
on the bread board with the breadboards power supply all is nice and working perfectly (3,3v setting on power supply)
when i change from breadboard power supply to the links above 3,3v ac to dc i will keep restarting. on the multi meter the readings go as low as 2,2v and rarely go higher than 2,6v.
i also have to add that on the esp8266-01 version i didn't even need the capacitor.
could you please advise me on what i could do in order to fix this issue.
should i buy an new power supply
can i make do with what i already have
(http://www.ebay.com/itm/191869830804?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/400982158473?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT)
thank you in advance for your time .I will greatly appreciate any helpful hint.
