By Joe Job
#52923 Well guys it is now complete, OTA programming via a system on my server, autonomous control by other devices on my network via my IoT platform (https://iot.techbubbletechnologies.com) and controllable via my Artificial Intelligence agent TOA, (https://ai.techbubbletechnologies.com).
Here is the video of my controlling the device with my AI if you want to check it out ;) Thanks to everyone that helped get this going, nearly gave up many times lol.
By trackerj
#52942 Very nice, well done!!
As I told you before ... "never give up, never surrender" :)
By KK4HFJ
#78404 I like to use a 150 ohm resistor in series with the gate to protect the ESP8266 in case of MOSFET failure. As mentioned, a 100k from gate to ground to endure cutoff. I use a 2N7000 MOSFET to drive the relay coil, and a 1N4148 diode across the relay coil to handle flyback.
