By schufti
#53080 Hi,
still missing some info:
your writing about breadboard so I suppose you are using a breakout board - which?
what module is it you are using?
what kind of step-up are you using?
did you ever look at the Vcc pin of the module (to be sure to have the most relevant point) with an o'scope in both situations?
By Joe Job
#53086
schufti wrote:Hi,
No breakout, soldered wires from resistor cut offs.
Step up has been mentioned: http://www.ebay.es/itm/272202545243 output is more than the programmer is outputting
ESP12f
Don't have oscilator but with multimeter, output is 3.22 roughly
