Delving into the SD and SdFat libraries to try to find the problems, I've been adding Serial.print statements for debugging, using a callback function in the sketch to get that to work within the libraries.
As I've added these statements, the non-performance has got steadily worse until finally the execution crashes and the sketch gets woken up by a watchdog timer, only to repeat.
I've traced the crash to File::File(SdFile f, const char *n) in File.cpp and by inserting return; at various places, have found that the crash occurs deeper in a malloc() or memcpy() call within that function.
Interestingly, using the String() family of operations, seems to use the heap as well as malloc().
Although the freeRAM() function I submitted here earlier is reporting heaps(:->) of heap available, thus perhaps ruling out a memory leak, my gut feeling is that somewhere the heap management system is running out of some resource - probably related to the number of calls on its services rather than the amount of heap allocated.
Anyway, I'm transferring my development to a Raspberry Pi zero for now although the PCB I've prototyped and the MCP2301x I2C I/O expander library will probably be useful elsewhere.
'bye for now.
Peter.
