Be really carefull to make sure that is in parallel with the 10k, with the 1K's between it and the GPIO's or any in rush current could dammage the GPIO's when you set GPIO 0 high.
Which PIR are you using? Is there anything in the code before you set GPIO 0 high?
When tested it only need a high of 325mS to remain stable.
