Report Bugs Here
Moderator: Mmiscool
By aphawk
#54901 I'm using some commands   to add spaces in the text to make a more precise positioning.
When I run, all is fine. Then I save the program, and if I open the program in the EDIT page, all my   was changed to blank spaces, and the program don't works as expected.
This is the original code that I saved:
Code: Select allwprint |<h3><font color="RED">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R<font color="GREEN">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;G<font color="BLUE">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;B</h3>|
This is the code after I open again the file saved:
Code: Select allwprint |<h3><font color="RED">                   R<font color="GREEN">     G<font color="BLUE">     B</h3>|
By Mmiscool
#54907 Would css and divs work better for producing perfect placement of items?
By aphawk
#54912 Hi Mmiscool,
Well, I don't know what is DIVS... sorry !!! I'm thinking about learn Css and Html basics, to better use this fantastic interpreter. If you tell me that I need to learn DIVS too, I will try !
For my 56 years, this is not easy at all....
But I'm reading a lot about CSS today. I'm learning bit a bit , but now I can positioning where I want.
You can show me another way to print letters with right color and positioning, without use of this &nbsp trick ?
Better yet, how I can Print a text directly in position x,y ( in px ), changing colors, in one easy way ?
This will help a lot to design the output screen in my programs,
Thanks.
By Mmiscool
#54913 A word of advice. Absolute positioning is normally a bad thing when it comes to web browsers.
it can be done using a bit of css.
Code: Select allslider x, 0 , 180
cssid htmlid(), "position:absolute;top:100; left:100;"
