Boards used Arduino UNO and ESP8266 ESP-07
Connections between boards as follows
UNO ESP-07
TX -- Txd0
RX -- Rxd0
ESP-07 connections as follows
Vcc -- +3v
Gnd -- Gnd
EN(CH_PD) -- +3.3v
RST -- open
GPIO 15 -- Gnd
Now I power up ARduino and esp module.
RED led of esp switches ON
I open ARduino IDE 1.6.6
open serial monitor (Baud rate 115200. NL&CR )
Now momentarily connect RST to Gnd.
It flashes following message...(see down below)
After that I type any AT command in the terminal window...it does nothing
No response back.
What is going wrong?
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
Ready
