By Orcanbull
#55561 Hi People;
So i've got a setup running very nicely with 2-4 ESP-E12
On the Master ESP i'm creating a SoftAP and a Server. Its sends at random times a messaged to the other slave ESP's
MASTER CODE
Code: Select allextern "C" {
#include "user_interface.h"
#include <WiFiClient.h>
#include <EEPROM.h>
#include <string.h>
#include <SoftwareSerial.h>
#define MAX_SRV_CLIENTS 6
WiFiServer server(23);
WiFiClient serverClients[MAX_SRV_CLIENTS];
WiFiClient client;
char Name[32] = "HELLOWORLD"; // Standard name part
char ID[8] ; // buffer of ID of the ESP8266 ID
IPAddress myIP;
int connected = 0 ;
const char *ssid = "SOFTAP";
const char *password = "123456789";
  Serial.begin(9600);
  itoa(ESP.getChipId(), ID, 10); // get ID of ESP
  // Convert ID to constant Char
  for (int i = 0; i < 8; i ++)
    Name[i + 12] = ID[i];
  wifi_station_disconnect();
  wifi_set_opmode(0x02); // SETTING IT TO AP MODE
  const char *ssid = Name;
  WiFi.softAP(ssid, password, 8, 0);
  myIP = WiFi.softAPIP();
  Serial.println(myIP);
  server.begin();
  server.setNoDelay(false);
  Serial.println("TCP Server Setup done");
  delay(5000);
  uint8_t i;
  //check if there are any new clients
  if (server.hasClient()) {
    connected = 0;
    for (i = 0; i < MAX_SRV_CLIENTS; i++) {
      //find free/disconnected spot
      if (!serverClients[i] || !serverClients[i].connected()) {
        if (serverClients[i]) serverClients[i].stop();
        serverClients[i] = server.available();
        Serial.print("New client: "); Serial.println(i);
        serverClients[i].print("00000010");
        continue;
      connected ++;
    Serial.print("Connected clients = ");
    Serial.println(connected);
    //no free/disconnected spot so reject
    WiFiClient serverClient = server.available();
    serverClient.stop();
  // Check for Data each time only 1 byte is expected and needed to be send
  if (Serial.available() > 0)
    byte temp_input = Serial.read();
    Serial.flush();
    String byte_message = "";
      byte_message += bitRead(temp_input, 7);
      byte_message += bitRead(temp_input, 6);
      byte_message += bitRead(temp_input, 5);
      byte_message += bitRead(temp_input, 4);
      byte_message += bitRead(temp_input, 3);
      byte_message += bitRead(temp_input, 2);
      byte_message += bitRead(temp_input, 1);
      byte_message += bitRead(temp_input, 0);          // TAKES THE 10001011 version of the Byte
      if (serverClients[i] && serverClients[i].connected()) {
        serverClients[i].print(byte_message);
        delay(1);
SLAVE CODE
extern "C" {
#include<WiFiUdp.h> // libary for UDp connections
const char* host = "192.168.4.1";
const int port = 23;
const char *ssid = "";
const char *password = "";
int status = 6;
WiFiClient client;
void fpm_wakup_cb_func1(void)  {
  wifi_fpm_close(); // disable force sleep function
  //wifi_set_opmode(STATION_MODE); // set station mode
  //wifi_station_connect();
  // Serial.println("Woken up...");
// LIGHT SLEEP FUNCTION
void sleepNow(int MILI) {
  // Serial.println("Going to sleep...");
  float sleepTime = millis();
  wifi_fpm_set_sleep_type(LIGHT_SLEEP_T); // light sleep
  wifi_fpm_open(); // enable force sleep
  wifi_fpm_set_wakeup_cb(fpm_wakup_cb_func1); // Set wakeup callback
  wifi_fpm_do_sleep(MILI * 1000);
  delay(MILI +1);
  Serial.begin(9600);
  WiFi.disconnect();
  delay(10);
  WiFi.mode(WIFI_STA);
   WiFi.begin(ssid, password);
   if (!client.connect(host, port))
        Serial.println("Failed Connection to Server");
        status = 1;
void loop()
  status = WiFi.status();
  if (status == 3 && client.available() < 1)   // if there is no data ready for Module go to sleep
    Serial.println("GO To SLEEP");
    sleepNow(10);
    Serial.println("WAKING UP");
  else
     // function to reconnect
        status = 1;
  else if (client.available() >0)
    String TEMP_Message = "";
  while (client.available() > 0)
    TEMP_Message += char(client.read());
  Serial.println("GOT message = " + TEMP_Message);
  client.flush();
Everything works perfect aslong as my sleepNOW function stays under the 15 miliseconds
I would like to have my slaves sleep for 100 mili and then check if there is something available for them
the problem is that whenever i increase the time the slave sleeps , the master stays in a loop or something for the sending to that node ater the client.print function
. You would say 100 mili shouldn't be a problem however if the Slave sleeps for 100 MILI the lag in my master is about 2 seconds before it continous from the client.print method.
Any thought on how i could make sure my master doesn't get stuck at the sending part when my slave nodes sleep ?
Kind Regards,
Orcanbull
