By MosheB
#55205 First of all thanks for the comment.
I would like to know how I can connect directly to a computer.
If there is no choice I will work without Arduino.
But this board is designed to connect and work with the Arduino,
So why not take advantage of this option?
By izbin
#55726
MosheB wrote:Thanks,
You right, it looks like regular module, but when I connect with UNO, I can not find the right board to select.
If your using an UNO then select uno. This seems like its just a shield . On google it looked like there was some talk about the switches on the shield.
Or you can program directly to the module using arduino ide.
-Yisrael
