Because I have to use the ports 80 and 81? because I can not use any port that I want to open on the router.
Explore... Chat... Share...
Moderator: Mmiscool
Mmiscool wrote:You need to port forward port 80 qnd 81 on your router in order to access the web interface from an external ip address. You can then send from your external ip address.
