- Wed Oct 19, 2016 9:46 pm
#56818
They ARRIVED! I had purchased
https://goo.gl/n22tzQ the ESP8266-07 carrier and they were waiting, the only issue seemed to be the carrier was missing schematics. It has three resistors and a place for a SOT 223 which I took for a voltage regulator like AMS1117-3.3, which I soldered in place. I tried to tack the ESP8266-100 to the carrier with lock-tite blue, that just made a mess, that stuff takes a while to harden. After I had everything soldered I had to hook two breadboards together, the carrier is too wide and leaves no means to plug jumpers in. I wired everything up and was ready to power test when it dawned on me I had better check out the resistors on the board to see what they were doing. There is no schematic, none, nowhere, 'We check with our landlord' response but not expecting much. Of the dozens of vendors selling the carriers listed no one has the schematic.
They do now.
I just noticed the boards are different, mine has a silkscreen with R1, R2 and R3 list from left to right with the resistors facing you, at any case the middle resistor is R2.
And the board I have.
The version of firmware from AI
OK
AT+GMR
AT version:0.40.0.0(Aug 8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
OK
And not to be defeated, I found a new release of the Flash_download_tool that now works on 8266/8285/esp32 and after downloading and installing it:
flash vendor:
EFh : WB
flash devID:
4017h
QUAD;64Mbit
crystal:
26 Mhz
The previous version V3.4.1 would die on 64mbit
The V3.4.2 version seems to work, will find out after I figure out how to install the latest firmware.
