alonewolfx2 wrote:I changed SDK folder into the espressif/examples/esp_iot_rtos_sdk and it's working now.
For change folder name in install -> file: .project:
<projectDescription>
<name>esp_iot_rtos_sdk</name>
Explore... Chat... Share...
pvvx wrote:Extract files ‘NodeLuaMake.zip’ – folder NodeLua
Files nodemcu - folder nodemcu-firmware-master
Eclipse:
File->Import->General->Existing Project into Workspace->Next->Browse… folder NodeLua, Check ‘Copy projects into workspace’, Finish.
Select progect ‘NodeLua’ -> Import->File System->Next->From … nodemcu-firmware-master, Into folder: ‘nodelua’. Check all files, Uncheck ‘Makefile’ into right panel. Finish.
Compile…
