'* Analog Panel Meter Clock *
'* by Russ McIntire, 10/19/16 *
'* D0 = Hours *
'* D1 = Minutes *
'* D2 = Seconds *
'* D4 = can vary intensity to show clock running *
'* currently commented out in code *
'* Shows hours/minutes/seconds on 3 panel displays *
'* Allows Timezone and DST settings from webpage *
'* Requires Internet connection for NTP time retrieval *
'* Sends UDP broadcast of current time *
'* Can update UDP Port in settings, default is 5001 *
'* Added WIFI configuration and reboot capability *
'* Added last NTP update retrieved to main web page *
'* Added calculation and update of DST for U.S. *
'* When powered up first time, go to http://192.168.4.1 *
'* 1) Enter timezone and DST (1=true, 0=false) first *
'* 2) Save timezone information *
'* 3) Change UDP port if desired and save *
'* 4) Enter SSID and password and save *
'* 5) Click reboot button *
'* Clock will restart with new settings within a minute *
'* If desired, note the MAC address shown when first *
'* connecting. Set this in your routers static DHCP *
'* If reconnection is desired for DST change, go to the *
'* clock's new IP address. It will be necessary to find *
'* it if the DHCP setting above is not performed. *
'* Scanning programs are available and they should show *
'* the name as ESPXXXXX *
memclear
'Get DST and Timezone info from memory
DST = read.val(DaylightSavings)
timezone = read.val(TZ)
udpportval = read.val(UdpPort)
wifiName = read(WIFIname)
wifiPass = read(WIFIpass)
if DST = 1 then
tz = timezone + 1
else
tz = timezone
endif
if udpportval = 0 then udpportval = 5001
udpbegin udpportval
timesetup(tz,DST)
delay 5000
hour = 0
min = 0
sec = 0
M = " "
udptimer = 0
hourpwm = 0
minpwm = 0
secpwm = 0
updated = 0
updatetimer = 0
cts = time("hour:min:sec")
lastNTP = "First boot "&time("month. day, year hour:min:sec")
uvsr = "Running..."
'Determine broadcast address
let localIP = ip()
pos = instrrev(localIP,".")
netIP = left(localIP,pos)
nodeIP = mid(localIP,pos+1)
let broadcastaddr = netIP & "255"
'GUI setup
cls
wprint |<HTML>|
wprint |<HEAD>|
wprint |<style> h1{text-shadow: 2px 2px 5px blue} </style>|
wprint |<h1>Analog Clock Setup</h1>|
wprint |</HEAD>|
wprint "The time is currently: "
wprint htmlvar(cts) ' time("hour:min:sec")
wprint "<br>"
wprint "Last NTP update: "
wprint htmlvar(lastNTP)
wprint "<br><br>"
textbox timezone
cssid htmlid(),"position: absolute; left: 110px; display:block;width:40px"
wprint "Timezone: "
wprint "<br>"
textbox DST
wprint "DST (1=DST):"
wprint "<br><br>"
button "Time Info Update", [timezone_update]
wprint "<br><br>"
textbox udpportval
cssid htmlid(),"position: absolute; left: 110px; display:block;width:60px"
wprint "UDP Port:"
wprint "<br><br>"
button "UDPPort Update", [udpport_update]
wprint "<br><br>"
textbox wifiName
cssid htmlid(),"position: absolute; left: 110px; display:block;width:110px"
wprint "WIFI Name:"
wprint "<br>"
textbox wifiPass
wprint "WIFI Pass:"
wprint "<br><br>"
button "Store WIFI Settings", [wifi_update]
wprint "<br> <br>"
button "Reboot Clock", [reboot_clock]
wprint "<br><br>"
wprint htmlvar(uvsr)
wprint "<br><br>"
wprint "-------------------------------------------- <br>"
n = wifi.scan()
wprint "Number of networks found = "&n&"<br>"
wprint "RSSI == BSSID == SSID <br>"
for i = 1 to n
wprint wifi.rssi(i)&" == "&wifi.bssid(i)&" == "&wifi.ssid(i)&"<br>"
next n
timer 1000, [updatetime]
wait
end
[updatetime]
'Get time values from NTP server
hour = val(time("hour"))
min = val(time("min"))
sec = val(time("sec"))
'For calibration (max meter swing)
'hour = 0
'min = 0
'sec = 59
'Set 12 hour time and determine AM/PM
if hour >= 12 then
hour = hour - 12
M = "PM"
else
M = "AM"
endif
'Panel PWM calculation
'hourpwm = 85.33 * (hour) 'divide 1024/12
hourpwm = (85.33 * hour) + (1.446 * min) 'divide 1024/12 add proportion of minutes (1.445/min)
minpwm = 17.36 * min 'divide 1024/59
'minpwm = (17.36 * min) + (.289 * sec) '- don't recommend - divide 1024/59 add proportion of seconds (.289/sec)
secpwm = 17.36 * sec 'divide 1024/59
'Panel output
io(pwo,d0,hourpwm)
io(pwo,d1,minpwm)
io(pwo,d2,secpwm)
'Daily NTP refresh at 2:00 AM
if ((hour=3) and (min=0) and (sec>0) and (sec<5) and (M="AM")) then
gosub [calculate_DST]
timesetup(tz,DST)
delay 5000
lastNTP = "Last NTP "&time("month. day, year hour:min:sec")
endif
gosub [udptimer]
wait
[timezone_update]
'Persist timezone information and UDPPort
write(DaylightSavings,str(DST))
write(TZ,str(timezone))
if DST = 1 then
tz = timezone + 1
else
tz = timezone
endif
timesetup(tz,DST)
delay 5000
'serialprintln "Timezone Updated"
'serialprintln "The Updated time is: "
'serialprintln time("hour:min")
uvsr = "<mark> Updated... </mark>"
updated = 1
returngui
wait
[udpport_update]
write(UdpPort,str(udpportval))
udpbegin udpportval
updated = 1
returngui
wait
[wifi_update]
write(WIFIname,wifiName)
write(WIFIpass,wifiPass)
uvsr = "<mark> Updated, requires a reboot to take effect... </mark>"
updated = 1
returngui
wait
[udptimer]
'Send UDP broadcast message out for current time every 30 seconds
udptimer = udptimer + 1
' io(pwo,d4,1024-udptimer*273) 'vary d4 intensity to show clock operating, can comment out if desired
if udptimer > 30 then
if (M = "PM" and hour = 0) then hour = 12
ct = str(hour)&":"&time("min:sec")&" "&M
udpwrite broadcastaddr, 5001, ct
udptimer = 0
endif
'Check to see if Timezone or DST was updated
if updated = 1 then
updatetimer = updatetimer + 1
if updatetimer > 9 then
uvsr = "Running..."
updated = 0
updatetimer = 0
returngui
endif
endif
return
[reboot_clock]
cls
print "REBOOTING..."
delay 1000
reboot
wait
[calculate_DST]
dow = time("dow")
day = time("day")
month = time("month")
hour = time("hour")
if ((DST = 1) and (dow = "Sun") and (month = "Nov") and (day >= 1) and (day < 8)) then
DST = 0
endif
if ((DST = 0) and (dow = "Sun") and (month = "Mar") and (day >=8) and (day < 15)) then
DST = 1
endif
return
Moderator: Mmiscool
Thanks for sharing :)
Where I buy my ESP8266 boards from... (Banggood)
