The larger the better and low esr preferred.
Explore... Chat... Share...
gvl wrote:To anyone having the same issue, make sure that your device is powered by a 3.3V power source capable of sourcing at least 200 mA of current. Also, remember to add a 10uF or so capacitor on the rails, and position the ESP8266 as close to the capacitor as possible. I was having the above issue too until I added the capacitor; now everything is rock solid.
If that still doesn't work, then reflashing might be a good idea.
