do you have any idea about why SD card is getting hot sometimes?
I've noticed if I insert SD card after starting my sketch (after getting error initialization fail) then SD card is getting so hot.
Thanks
Navid
Explore... Chat... Share...
Initializing SD card...Wiring is correct and a card is present.
Card type: SD2
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
