craigfoo wrote:Using WiFiManager.resetSettings() was a winner, thanks!
void WiFiManager::resetSettings() {
DEBUG_WM(F("settings invalidated"));
DEBUG_WM(F("THIS MAY CAUSE AP NOT TO START UP PROPERLY. YOU NEED TO COMMENT IT OUT AFTER ERASING THE DATA."));
WiFi.disconnect(true);
//delay(200);
umm ... so the answer was really "WiFi.disconnect(true);" ...
craigfoo wrote:Thanks for the reply.
What if I wanted to implement a "factory reset" using a button? I want to programmatically erase all Wifi profiles that are saved in flash. I played around with the system_restore API and I think it's working but there might be a better way.
Hi Craigfoo, have you figured out the solution yet? I'm trying to implement same thing but no luck. I want to connect a switch to GPIO0 or GPIO2 so that I should be able to Reset the WifiManager and SPIFFS.format() configurations.
If you have the solution would you please share it. It help be a great help. Thanks
