Moderator: Mmiscool
By Electroguard
#58365 That's a bit like asking "How long is a piece of string?"
You call it a wifi camera, but wifi is often used for simple video streaming from cameras which cannot be connected to.
So presumably you must be talking about an IPcamera, but take a look at an IPcamera viewing software and it will cater for hundreds - if not thousands - of different makes and models of IPcamera's, all with their own specific features and protocols and quirks... so which one of those is yours???
I suspect for security and performance reasons the connection transport protocol would probably be TCP, and Esp_Basic only has UDP implemented.
So I'm afraid can already see some big potential problems in the way.
By blupassat
#58372 Hi,
thanks a lot.
The camera is an action camera and I developped an android app for it.
The action camera accepts the command like "http://192.168.xxx" for start, stop and other functions.
In my android app i used http command and the camera respond correctly.
I think that if espbasic don't use tcp protocol this operations can't work with this action camera.
I suppose that i must to look another Language for esp8266.
Thanks in advance
Bye
By Mmiscool
#58406 If all you have to do is tug on a url using http then the wget() function will work for you.
Code: Select allWget("192.168.1.100/takepic")
