- Wed Nov 23, 2016 11:50 pm
#58595
Hello everyone, I am working on a project in which I am collecting data from different sensors and then transmitting the data packet through ethernet shield towards my local database. Main issue i am facing right now is After connection break I am loosing my data, so I figured that i should use Micro SD card for that period.
Coming towards my main question, Both ethernet shield and micro SD card module uses same SPI pins, and I am unable to get them working in parallel. Is there anyway we can use these modules in parallel.
I am also attaching pictures of ESP8266 12E, ethernet shield and Micro sd Card module, which i am using for the project.
Thank you all for your time.
