- Tue Dec 13, 2016 7:07 pm
#59478
This sounds like a cool project, and it looks like you have a good handle on it. I would perhaps go with another module, such as an 01 or 07. A module without the on board 3.3V regulator. I would look on ebay for a switching 3.3V regulator and use that. The more typical regulators on the boards are pass element regulators that dissipate the voltage difference as heat. A switching regulator is much more efficient. The steady state dissipation of that regulator will be many times the power consumption of the 8266 when it is deep sleeping. The other thing I would so is nix all of the LED's on the boards. Again, the LED's are just wasted power.
I would start with a bench power supply and a few ohms in series with the V+. Hook your scope up across that resistor and get a picture of the current consumption. My guess is you are going to see a lot of little spikes, which is why just using a DVM would not be a good idea. Once you have an idea of how much power you are going to be consuming, you can start to figure out what you need for solar cells and batteries.
Don't forget that we are going into winter. That brings up some issues for solar. One is that the days get a lot shorter so you want to make sure you can top them off on the worst of days. Next, if you are in a cold climate, you may get snow or frost build up on the solar panels (assuming that this will be outside and unattended..) Clever mounting of the solar cells can help with snow. Keep them as near vertical as possible. Next, most batteries don't work at peak efficiency when they get very cold. Don't forget that a battery is an electrochemical reaction and most chemical reactions are retarded by cold. Packing the battery pack in some foam or other insulating material may help there. And last, if this will be outside and unattended, it is going to get hot and cold so there will be both expansion and contraction issues as well as dew issues. Putting everything but the sensor in a very tight fitting enclosure may help there, as well as adding a bag of silica gel.
I have not pondered running an 8266 on solar, but I have often times pondered making a solar powered wifi repeater to get a decent signal in my woods, and they seem to share a lot of issues.
Your sounds like a cool project. Please follow up here if you move on it!
