By ColbyL
#59835 Hi!
I've been using Adafruit's Huzzah board for a couple of months. Everything was going great, but all of a sudden, the Arduino IDE (1.8.0) takes 30 minutes or more to compile even the simple Blink sketch on a new Windows 10 machine.
I've uninstalled and reinstalled everything, including the ESP8266 board manager stuff, but the problem persists. I've tried everything in the forums about this, but nothing works.
Any ideas why this would happen?
ColbyL
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\colby\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\colby\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\colby\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=nodemcu,Debug=Serial,DebugLevel=all_____ -ide-version=10800 -build-path C:\Users\colby\AppData\Local\Temp\arduino_build_527629 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\colby\AppData\Local\Temp\arduino_modified_sketch_584109\sketch_dec22a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\colby\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\colby\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\colby\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=nodemcu,Debug=Serial,DebugLevel=all_____ -ide-version=10800 -build-path C:\Users\colby\AppData\Local\Temp\arduino_build_527629 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\colby\AppData\Local\Temp\arduino_modified_sketch_584109\sketch_dec22a.ino
Using board 'generic' from platform in folder: C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Build options changed, rebuilding all
Detecting libraries used...
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_SSL -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_CLIENT -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_SERVER -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_TLS_MEM -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp" -o "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_SSL -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_CLIENT -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_SERVER -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_TLS_MEM -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp" -o "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp" -o "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp.o"
Compiling sketch...
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -Wall -Wextra -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_SSL -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_CLIENT -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_SERVER -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_TLS_MEM -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp" -o "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\sketch\sketch_dec22a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\colby\AppData\Local\Temp\arduino_build_527629/core" -c -g -x assembler-with-cpp -MMD -mlongcalls -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10800 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\colby\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\cont.S" -o "C:\Users\colby\AppData\Local\Temp\arduino_build_527629\core\cont.S.o"
