By GinYP
#60151 Hello, I'm new in Arduino & IoT, I'm building simple project that can control electronic device using ESP12E AI Thinker, MQTT and HomeAssistant. The system & UI worked fine until I add/edit some GPIO as an input.
The "if function" that use "status3" as a trigger and publish into topic ("ins/room6/status", "1") or ("ins/room6/status", "0") make Serial monitor display "Attempting Connection .... MQTT COnnected" after Callback updated into topic ("ins/room6").
If I delete that "if function" that use "status3" the system works fine, but I need to use "status3" to send a topic payload.
Is there anything wrong with my code?
Big thanks for help.
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <PubSubClient.h>
#define MQTT_SERVER "xx.xx.xx.xx"
const char* ssid = "xxxxxxxx";
const char* password = "xxxxxxx";
const int lightPin1 = 15;
const int lightPin2 = 12;
const int lightPin3 = 14;
const int push1 = 5;
const int push2 = 4;
const int push3 = 9;
char* lightTopic1 = "ins/room1";
char* lightTopic2 = "ins/room2";
char* lightTopic3 = "ins/room3";
char* lightTopic4 = "ins/room4";
char* lightTopic5 = "ins/room5";
char* lightTopic6 = "ins/room6";
WiFiClient wifiClient;
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
  pinMode(lightPin1, OUTPUT);
  pinMode(lightPin2, OUTPUT);
  pinMode(lightPin3, OUTPUT);
  pinMode(push1, INPUT_PULLUP);
  pinMode(push2, INPUT_PULLUP);
  pinMode(push3, INPUT_PULLUP);
  WiFi.begin(ssid, password);
  reconnect();
  delay(2000);
void loop(){
  if (!client.connected() && WiFi.status() == 3) {reconnect();}
  client.loop();
  int status1 = digitalRead(push1);
  int status2 = digitalRead(push2);
  int status3 = digitalRead(push3);
  if(status1==0){
  client.publish("ins/room4/status", "1");
  Serial.print("sensor1 : ");
  Serial.println(status1);
  }else if (status1==1){
  client.publish("ins/room4/status", "0");
  if(status2==0){
  client.publish("ins/room5/status", "1");
  Serial.print("sensor2 : ");
  Serial.println(status2);
  }else if (status2==1){
  client.publish("ins/room5/status", "0");
  if(status3==0){
  client.publish("ins/room6/status", "1");
  Serial.print("sensor3 : ");
  Serial.println(status3);
  }else if (status3==1){
  client.publish("ins/room6/status", "0");
  delay(100);
void callback(char* topic, byte* payload, unsigned int length) {
  String topicStr = topic;
  Serial.println("Callback update.");
  Serial.print("Topic: ");
  Serial.println(topicStr);
  if(topicStr.equals(lightTopic1)){
    if(payload[0] == '1'){
       digitalWrite(lightPin1, HIGH);
      client.publish("ins/room1/status", "1");
    else if (payload[0] == '0'){
      digitalWrite(lightPin1, LOW);
      client.publish("ins/room1/status", "0");
  if(topicStr.equals(lightTopic2)){
       digitalWrite(lightPin2, HIGH);
      client.publish("ins/room2/status", "1");
      digitalWrite(lightPin2, LOW);
      client.publish("ins/room2/status", "0");
  if(topicStr.equals(lightTopic3)){
       digitalWrite(lightPin3, HIGH);
      client.publish("ins/room3/status", "1");
      digitalWrite(lightPin3, LOW);
      client.publish("ins/room3/status", "0");
  if(topicStr.equals(lightTopic4)){
  if(topicStr.equals(lightTopic5)){
  if(topicStr.equals(lightTopic6)){
void reconnect() {
  if(WiFi.status() != WL_CONNECTED){
    Serial.println(ssid);
    Serial.println("");
  if(WiFi.status() == WL_CONNECTED){
    while (!client.connected()) {
      Serial.print("Attempting MQTT connection...");
      String clientName;
      clientName += "esp8266-";
      uint8_t mac[6];
      WiFi.macAddress(mac);
      clientName += macToStr(mac);
      if (client.connect((char*) clientName.c_str())) {
        Serial.print("\tMTQQ Connected");
        client.subscribe(lightTopic1);
        client.subscribe(lightTopic2);
        client.subscribe(lightTopic3);
        client.subscribe(lightTopic4);
        client.subscribe(lightTopic5);
        client.subscribe(lightTopic6);
      else{Serial.println("\tFailed."); abort();}
String macToStr(const uint8_t* mac){
  String result;
  for (int i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5){
      result += ':';
  return result;
By RichardS
#60167 Status3 uses pin 9 which most of the time is used by the ESP8266 module itself for the internal serial flash IC.
Make sure its truly available..... Some modules yes and most no.
RichardS
By GinYP
#60174 Thanks for information, before use pin 9, I tried using 0, 2, 4, 5, 10 but the result is same, still "restart" attempting connection when reaching callback update of lightTopic6. Any other solution/suggestion?
Is there any rule of using any GPIO as input/output??
Are we can use all of GPIO as input/output/both? Because I'm stuck using max 6 GPIO as output of ESP12E AI Thinker
By RichardS
#60203 You can use 12,13,14,16,4,5,0,2,15
Make sure 15 is low at reset and 0,2 are high, then it will be OK.
Also make sure 16 is not connected to reset as it is in some modules, this is used to deep sleep wakeup.
RichardS
