By hubbe
#60270 Hello all, first of English is not my best language to write in but I will try. :D
This weekend I was playing around for the first time with ESP8266 and I somehow managed to get values to Thingspeak.
Good guide for other newbie like me:
http://www.esp8266learning.com/dht11-se ... mos-d1.php
https://www.hackster.io/vsaravind007/es ... 3&offset=4
What I like to do now is the following, I want to read the temperature from Thingspeak to another wemos with a relay shield for open a heating valve with a like a simple code
if temp_thingspeak < 23 the relay 1
if temp_thingspeak > 23 the relay 0
Is this something that can be done or do I need to have a home automation server like OpenHAB to do this ?
/Hubbe
By ptribbey
#60365 Maybe this link will help you:
https://www.mathworks.com/help/thingspeak/thingspeakread.html?requestedDomain=www.mathworks.com
You can read any thingspeak channel and manipulate the received data as you wish.
