I tried many things and spend 2 days in this until I get some posts about my USB to Serial with FTDI chip having problem.
http://img.banggood.com/thumb/view/upload/2012/lidanpo/SKU116803%20(1).jpg
http://www.banggood.com/Geekcreit-Doit-NodeMcu-Lua-ESP8266-ESP-12E-WIFI-Development-Board-p-985891.html
I found this case an then I tried something different.
http://www.esp8266.com/viewtopic.php?f=6&t=2113
I'm using an Arduino Uno as USB2Serial Converter and it is working perfectly. Just remove the IC and use a Level Converter on the RX and TX pins (5v to 3.3v).
that adding:
ESP.wdtDisable(); ESP.wdtEnable(WDTO_8S); in Setup();
and
ESP.wdtFeed(); in Loop(); should fix it but again no luck.
I don't think its a power supply issue because it runs smoothly for 15-20 minutes.
Any Help will be appreciated. Thanks in Advance.
#include <ESP8266WebServer.h>
#include <WiFiUDP.h>
const char* ssid = "---"; // your network SSID (name)
const char* pass = "---"; // your network password
const char* friendlyName = "Arduino"; // Alexa will use this name to identify your device
const char* serialNumber = "221517K0101768"; // anything will do
const char* uuid = "904bfa3c-1de2-11v2-8728-fd8eebaf492d"; // anything will do
// Multicast declarations
IPAddress ipMulti(239, 255, 255, 250);
const unsigned int portMulti = 1900;
const unsigned int webserverPort = 9876;
// Witty Cloud Board specifc pins
const int LED_PIN = 13;
//int status = WL_IDLE_STATUS;
WiFiUDP Udp;
byte packetBuffer[512]; //buffer to hold incoming and outgoing packets
ESP8266WebServer server(webserverPort);
// UDP Multicast Server
char* getDateString()
//Doesn't matter which date & time, will work
//Optional: replace with NTP Client implementation
return "Wed, 29 Jun 2016 00:13:46 GMT";
void responseToSearchUdp(IPAddress& senderIP, unsigned int senderPort)
Serial.println("responseToSearchUdp");
//This is absolutely neccessary as Udp.write cannot handle IPAddress or numbers correctly like Serial.print
IPAddress myIP = WiFi.localIP();
char ipChar[20];
snprintf(ipChar, 20, "%d.%d.%d.%d", myIP[0], myIP[1], myIP[2], myIP[3]);
char portChar[7];
snprintf(portChar, 7, ":%d", webserverPort);
Udp.beginPacket(senderIP, senderPort);
Udp.write("HTTP/1.1 200 OK\r\n");
Udp.write("CACHE-CONTROL: max-age=86400\r\n");
Udp.write("DATE: ");
Udp.write(getDateString());
Udp.write("\r\n");
Udp.write("EXT:\r\n");
Udp.write("LOCATION: ");
Udp.write("http://");
Udp.write(ipChar);
Udp.write(portChar);
Udp.write("/setup.xml\r\n");
Udp.write("OPT: \"http://schemas.upnp.org/upnp/1/0/\"); ns=01\r\n");
Udp.write("01-NLS: ");
Udp.write(uuid);
Udp.write("\r\n");
Udp.write("SERVER: Unspecified, UPnP/1.0, Unspecified\r\n");
Udp.write("X-User-Agent: redsonic\r\n");
Udp.write("ST: urn:Belkin:device:**\r\n");
Udp.write("USN: uuid:Socket-1_0-");
Udp.write(serialNumber);
Udp.write("::urn:Belkin:device:**\r\n");
Udp.write("\r\n");
Udp.endPacket();
void UdpMulticastServerLoop()
int numBytes = Udp.parsePacket();
if (numBytes <= 0)
return;
IPAddress senderIP = Udp.remoteIP();
unsigned int senderPort = Udp.remotePort();
// read the packet into the buffer
Udp.read(packetBuffer, numBytes);
// print out the received packet
//Serial.write(packetBuffer, numBytes);
// check if this is a M-SEARCH for WeMo device
String request = String((char *)packetBuffer);
int mSearchIndex = request.indexOf("M-SEARCH");
int mBelkinIndex = request.indexOf("urn:Belkin:device:"); //optional
if (mSearchIndex < 0 || mBelkinIndex < 0)
return;
// send a reply, to the IP address and port that sent us the packet we received
responseToSearchUdp(senderIP, senderPort);
// HTTP Server
void handleRoot()
Serial.println("handleRoot");
server.send(200, "text/plain", "Tell Alexa to discover devices");
void handleSetupXml()
Serial.println("handleSetupXml");
String body = "<?xml version=\"1.0\"?>\r\n";
body += "<root>\r\n";
body += " <device>\r\n";
body += " <deviceType>urn:OriginallyUS:device:controllee:1</deviceType>\r\n";
body += " <friendlyName>";
body += friendlyName;
body += "</friendlyName>\r\n";
body += " <manufacturer>Belkin International Inc.</manufacturer>\r\n";
body += " <modelName>Emulated Socket</modelName>\r\n";
body += " <modelNumber>3.1415</modelNumber>\r\n";
body += " <UDN>uuid:Socket-1_0-";
body += serialNumber;
body += "</UDN>\r\n";
body += " </device>\r\n";
body += "</root>";
String header = "HTTP/1.1 200 OK\r\n";
header += "Content-Type: text/xml\r\n";
header += "Content-Length: ";
header += body.length();
header += "\r\n";
header += "Date: ";
header += getDateString();
header += "\r\n";
header += "X-User-Agent: redsonic\r\n";
header += "SERVER: Unspecified, UPnP/1.0, Unspecified\r\n";
header += "connection: close\r\n";
header += "LAST-MODIFIED: Sat, 01 Jan 2000 00:00:00 GMT\r\n";
header += "\r\n";
header += body;
Serial.println(header);
server.sendContent(header);
void handleUpnpControl()
Serial.println("handleUpnpControl");
//Extract raw body
//Because there is a '=' before "1.0", it will give the following:
//"1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>
String body = server.arg(0);
//Check valid request
boolean isOn = body.indexOf("<BinaryState>1</BinaryState>") >= 0;
boolean isOff = body.indexOf("<BinaryState>0</BinaryState>") >= 0;
boolean isValid = isOn || isOff;
if (!isValid) {
Serial.println("Bad request from Amazon Echo");
Serial.println(body);
server.send(400, "text/plain", "Bad request from Amazon Echo");
return;
//On/Off Logic
if (isOn) {
digitalWrite(LED_PIN, 1);
Serial.println("Alexa is asking to turn ON a device");
server.send(200, "text/plain", "Turning ON device");
else {
digitalWrite(LED_PIN, 0);
Serial.println("Alexa is asking to turn OFF a device");
server.send(200, "text/plain", "Turning OFF device");
void handleNotFound()
Serial.println("handleNotFound()");
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup()
// Open serial communications and wait for port to open:
ESP.wdtDisable();
// Initialize LED pin
pinMode(LED_PIN, OUTPUT);
// setting up Station AP
WiFi.begin(ssid, pass);
// Wait for connect to AP
Serial.print("[Connecting to ");
Serial.print(ssid);
Serial.print("]...");
int tries=0;
delay(200);
tries++;
if (tries > 50)
break;
// print your WiFi info
IPAddress ip = WiFi.localIP();
Serial.print(WiFi.SSID());
Serial.print(" with IP: ");
Serial.println(ip);
//UDP Server
Udp.beginMulticast(WiFi.localIP(), ipMulti, portMulti);
Serial.print("Udp multicast server started at ");
Serial.print(ipMulti);
Serial.print(":");
Serial.println(portMulti);
//Web Server
server.on("/", handleRoot);
server.on("/setup.xml", handleSetupXml);
server.on("/upnp/control/basicevent1", handleUpnpControl);
server.onNotFound(handleNotFound);
server.begin();
Serial.print("HTTP server started on port ");
Serial.println(webserverPort);
void loop()
UdpMulticastServerLoop(); //UDP multicast receiver
server.handleClient(); //Webserver
ESP.wdtFeed();
