By alex_g
#60874 I had a similar problem a while back, weak signal from the output pin had to be boosted (it was an analog signal too, iirc, from a DAC). Someone recommended I use an op-amp setup to boost the signal, and it worked a treat!
I still have the unit, built it easily with just one chip, a 4-op amp LM324 jobbie.
By the way, like yourself, I am more of a programmer, and know very little about electronics. So if I could do it, you probably could, too. The design is something like this: http://www.eleccircuit.com/increase-out ... 85ma-size/
Only thing I'm not sure is if the 85mA output is enough for you.
By Drpepper
#60950
alex_g wrote:I had a similar problem a while back, weak signal from the output pin had to be boosted (it was an analog signal too, iirc, from a DAC). Someone recommended I use an op-amp setup to boost the signal, and it worked a treat!
Thanks, it is so interesting just how many ways there are to do the same thing.
I took yesterday off, and spend the day on YouTube transistors theory. The Math is impressive.
