- is there a way to make esp8266 module send IR remote signal to control devices so that I can make home automation?
- is there a place to find a remote signal database?
Explore... Chat... Share...
Piira wrote:Espressif has an example that can be used as a base for an IR transmitter.
http://bbs.espressif.com/viewtopic.php?f=31&t=1199
I
