I'm using a nodemcu and an arduino mega in order to exchange data and then send the data to a server.
After a little bit of tweaking I was able to send data from nodemcu to mega, and I can see the data arriving without any problems.
The thing is that when I try to send data from mega to nodemcu, the data doesn't arrive. And I mean that it physically doesn't get to the board.
I connect the output of the mega's uart3 to 3 10k resistors and reduce the siganl from 5V to 3V3 approximately. When I don't connect the nodemcu I can see the data in an oscilloscope. My byte is there @3V3. But as soon as I connect the pin to the nodemcu It goes to 0V and there is no more signal. It was connected in Rx pin of nodemcu.
Naturally I thought that maybe the CH30 usb-serial converter is driving the pin to 0V or maybe some software on my computer is doing it. So I used the Serial.swap function in order to use TX2 and RX2 instead of TX0 and RX0.
Again I can easily get the data from nodemcu, but I can't send data to nodemcu. The same thing happens, it goes to 0V as soon as I connect it to nodemcu. Obviously the TX and RX are both working as they should, or else I wouldn't be able to flash new firmwares nor debug the output via serial port.
I'm thinking that there must be something wrong with my code.
Serial.begin(9600);
Serial.swap();
if(Serial.available()) {
uint8_t data = Serial.read();
Serial.write(data);
As you can see it's extremely simple. Wait until data arrives and send it back, but data never arrives.
