By hakha4
#63141 I have an ESP01 connected to 6 DS1820 sensors working fine but to get it work I had to use a strong pullup with a 680 ohm resistor from trial and error. The problem is that I need another sensor but I can't make it to work no matter what pullup resistor used. If hooked up with and Arduino at 5v no problem with 7 sensors. The cables are relatively short cat 5 so this shouldn't be the problem. The sensors are in parasitic mode and built in in heater tanks so not easy to change to power mode. I gather the main problem is that the ESP can't produce enough current to the sensors.
Has anyone tried to use a bidirectional level shifter like (http://www.ebay.com/itm/5pcs-2-CH-I2C-I ... 33a574d287)?
If this isn't impossible on what side should the pullup be,3.3v or 5v side ?
Any help appreciated
Regards Håkan
By piersfinlayson
#63172
hakha4 wrote:I have an ESP01 connected to 6 DS1820 sensors working fine but to get it work I had to use a strong pullup with a 680 ohm resistor from trial and error. The problem is that I need another sensor but I can't make it to work no matter what pullup resistor used. If hooked up with and Arduino at 5v no problem with 7 sensors. The cables are relatively short cat 5 so this shouldn't be the problem. The sensors are in parasitic mode and built in in heater tanks so not easy to change to power mode. I gather the main problem is that the ESP can't produce enough current to the sensors.
Regards Håkan
Probably not very helpful given what you've said, but I've had no problems running 8 DS18B20s in power mode (powered by 3.3V), with a very weak pull up (the ESP8266's built in pull-up was just fine!).
By piersfinlayson
#63199
hakha4 wrote:Maybe the parasite mode is the main issue. BTW what library for Ds1820 are you using?
I think I did try parasitic mode a while ago but had no success.
I've based my code on some from here: https://github.com/nekromant/esp8266-frankenstein
Which in turn was based on: http://www.pjrc.com/teensy/td_libs_OneWire.html
My code is here: https://github.com/piersfinlayson/otb-i ... _ds18b20.c
